Althen
Measuring amplifier suitable for IoT
LCB is a universal measuring amplifier for load cells from Althen Sensors & Controls which, according to the manufacturer, meets 'Industry 4.0' requirements and is designed especially for IoT needs.
© Althen
The measuring amplifier converts the analogue measuring signal (mV/V) of a strain gauge sensor into a digital signal and thus enables the subsequent digitization of a measuring chain - without replacing the existing load cell.
It is also compatible with any type of strain gauge sensor to which it is directly connected. Adapters can be used in certain cases.
For integration into the system environment with PLCs, the measuring amplifier works with various fieldbuses, the number of which is constantly being expanded. Modbus TCP, Ethernet TCP/IP, Ethernet/IP, Ethercat, Powerlink, Sercos III and Profinet IO are currently supported. Versions for IO-Link, CANopen,
Hesch
Incorrect measurements excluded
The HE 5422 differential pressure regulator from Hesch has been redesigned: Thanks to the pre-coating functionality, the cleaning process is significantly simplified and the Datahold function eliminates incorrect measurements.
AMO
Operating cobots safely
AMO's measuring devices measure position values with deviations of less than 1 µm per signal period, which enables precise positioning of robot axes and thus the safe operation of cobots in close proximity to human workers.
Janitza electronics
Say goodbye to load peaks
Peak loads are expensive. Even one-off 'slips' cause additional costs in the five-figure range. However, the obvious solution of temporarily switching off large consumers such as heating systems must not compromise process reliability. Modern...
TWK
Detect alignment and speed simultaneously
TWK has expanded its family of inclination sensors with a special device that makes it possible to precisely measure the current orientation - i.e. the inclination or position (360°) - and the speed at the same time in a rotating application.
