IOSS
Legibility across all stages of a process chain
The IOSS verifier can perform a reliable and reproducible quality assessment of DPM codes both offline and inline, in addition to the normal reading of codes.
© IOSS
This means that reading problems are detected at an early stage and can be rectified. The codes are recorded with standard-compliant lighting and evaluated in accordance with ISO/IEC 15415/TR 29158.
For needle-marked DPM codes, the provider has created its own validation standard 'Evaluated Reading' with special criteria that enable reliable and reproducible monitoring of the marking quality. Evaluated reading' is also suitable as a tool for analyzing trends and monitoring needle wear in the process. With the 'Q-Report' software, it is possible to create a corresponding proof of quality as a PDF document. This means that customers can be informed at any time about the quality and legibility of the coding supplied.
Baumer
A perfect fit in five steps
Laser distance sensors ensure process efficiency in automated production processes with the help of non-contact measurements. When choosing the right sensor, factors such as measuring range, focus, beam shape or object surface as well as ease of use...
Balluff
Smart sensor technology for the IIoT
In addition to status information, intelligent sensors provide a wealth of secondary data - on service life, load level and damage detection as well as ambient temperature or contamination. Optical sensors in particular are undergoing a lot of...
Couchbase
These are the AI trends for 2024
Artificial intelligence is changing the entire IT world forever and is having a huge impact on how data is understood, analyzed and used. AI is also taking data management to a new level. Five AI trends have been identified for the year 2024.
