Meilhaus Electronic
Measurement data acquisition with up to 5000 measurements/s
The DAQ973A from Keysight is a modular measurement data acquisition system with USB, LAN and GPIB interfaces, consisting of a basic device and a selection of nine measurement modules.
© Meilhaus
The basic device offers space for up to three measuring modules and can be used as a 6½-digit
multimeter, as a data logger and as a switching system. The digital multimeter works with a maximum scan rate of 450 channels per second and measures temperatures, DC and AC voltage, DC and AC current, resistances and frequencies. As a switching system, the 'DAQ973A' functions as a 'switch', i.e. switch/multiplexer/matrix or signal interconnection.
The device offers measurement rates of up to 5000 measurements/s and also measures very low current ranges, high resistance and voltage ranges as well as a wide temperature range. The device offers 120 measuring channels in 1-wire connection and 60 measuring channels in 2-wire connection.
Hesch
Incorrect measurements excluded
The HE 5422 differential pressure regulator from Hesch has been redesigned: Thanks to the pre-coating functionality, the cleaning process is significantly simplified and the Datahold function eliminates incorrect measurements.
Janitza electronics
Say goodbye to load peaks
Peak loads are expensive. Even one-off 'slips' cause additional costs in the five-figure range. However, the obvious solution of temporarily switching off large consumers such as heating systems must not compromise process reliability. Modern...
Meilhaus
Field-ready and battery-powered
Meilhaus offers the 'Metrahit' AM, PM and IM multimeter series from GMC-I/Gossen Metrawatt. The 'AM' series provides TRMS (True Root Mean Square) universal multimeters with 12,000 digits digital display and consists of the 'AM Base', 'AM Pro', 'AM...
