Research on Quantum Computers
Melanie Steinbeck,
A quantum computer that performs calculations using oscillations
Researchers at ETH Zurich are developing a quantum chip with mechanical memory. Instead of storing information electromagnetically, they store it in tiny vibrations. This approach could help build more powerful and compact quantum computers in the future.
The new quantum chip developed by ETH physicist Yiwen Chu contains so-called mechanical resonators—tiny components that begin to oscillate when storing information. The chip is about 7.5 millimeters long, 2.5 millimeters wide, and 1 millimeter high—roughly as wide as a small fingernail. © Hybrid Quantum Systems Group / ETH Zurich
This computer works almost like a guitar. Except that no one can hear its sounds. The vibrations generated on ETH Zurich’s new quantum chip occur deep inside the component. They are not used to make music, but to store quantum information.
ETH physicist Yiwen Chu and her team have developed a new architecture for quantum computers in which information is stored in mechanical oscillations. To achieve this, the researchers connect so-called mechanical resonators to superconducting qubits, the central processing units of a quantum computer.
The new quantum chip is small
The new quantum chip is about 7.5 millimeters long, 2.5 millimeters wide, and 1 millimeter high—roughly as wide as a small fingernail. Inside, there are tiny components that begin to oscillate when storing information.
“The way the processing unit and memory interact lays a crucial foundation for establishing quantum computers as powerful and reliable tools for calculations that are not possible with conventional computers,” says Yiwen Chu.
The physics professor conducts research on quantum information and quantum computer architectures. Together with her team, she has presented an approach that separates the actual computation from storage more clearly than many previous quantum computer models.
Memory modeled after classic computers
The idea is based on the architecture of conventional computers: In such systems, a central processing unit—the processor (CPU)—processes data that is stored separately in random access memory (RAM). This separation makes it possible to process information efficiently.
Chu's quantum computer also follows this principle. A superconducting qubit serves as the computing and control unit. The information, on the other hand, is stored in a quantum memory and remains available during the calculation.
The difference from previous approaches lies in the memory itself. While many quantum computers use electromagnetic memory, Chu relies on mechanical vibrations.
“In our quantum memory, however, information is not stored electromagnetically—as is usually the case today—but in the form of mechanical vibrations,” says Chu.
The qubit accesses stored information, processes it, modifies it, and then stores it back in memory.
"Specifically, our quantum chip contains what are known as mechanical resonators. These are tiny components that begin to oscillate when data is stored," says Chu.
Many types of vibrations, more memory slots
The way it works is similar to that of a guitar string. Depending on how it vibrates, it produces a different sound. Mechanical resonators can also vibrate in different ways. Experts refer to these as vibration modes.
In computer science, these modes correspond to different memory locations. Each type of oscillation can store different information. In addition, different oscillation states can arise within these modes—that is, specific states in which information is stored and retrieved.
The key difference from the guitar lies in quantum physics. The vibrations of a string follow the rules of classical physics. In a quantum chip, however, the laws of quantum mechanics apply. There, states can overlap and become entangled with one another.
These characteristics fundamentally distinguish quantum computers from classical computers. Digital computers operate with two clearly distinct states: 0 or 1. Quantum computers, on the other hand, can consider multiple possibilities simultaneously. As a result, they may one day be able to solve certain complex problems much more efficiently than conventional computers.
Mechanical storage devices are smaller and more reliable
For a quantum computer to operate reliably, researchers must be able to precisely control and manipulate quantum states. The interaction between the processing unit and the memory is crucial in this regard.
In Chu's approach, the resonators store information in specific vibrational states. When the qubit retrieves information, it alters this state and then stores it back again.
To date, many quantum computer models have been combined with electromagnetic memory. This technology has been well researched and allows for precise control of quantum states. However, such memory has one drawback: it requires a relatively large amount of space.
This could hinder the development of experimental laboratory equipment into practical quantum computers for research and industry.
Mechanical resonators, on the other hand, are smaller and more compact. They can also store more information because they have many different vibration modes. In addition, the stored quantum states remain stable for longer without the vibration diminishing and information being lost.
Proof of Concept for a New Quantum Architecture
In their paper, Chu and her team demonstrate experimentally for the first time that mechanical resonators can be coupled with superconducting qubits and used for quantum computations.
The researchers have thus demonstrated that this is feasible: an oscillating memory could be an alternative to the electromagnetic memory devices used to date.
Whether this approach will prevail in the long term depends on whether it can be scaled up to larger systems. The quantum chip must continue to function reliably even if quantum computers are expected to offer significantly more computing power in the future.
The research group has already tested its architecture on more challenging tasks. These included the quantum Fourier transform and period determination—two important methods in quantum computing.
“The quantum Fourier transform is a fundamental computational method required for many quantum algorithms. The algorithm we implemented for period determination demonstrates how this method can be applied,” explains Igor Kladaric, a doctoral student on Chu’s team and co-author of the publication.
Both methods require that a quantum computer be able to precisely store, control, and interconnect many quantum states simultaneously. It is precisely this capability that the ETH researchers' approach demonstrates.
A step toward a programmable quantum computer
Yiwen Chu's system is capable of performing the basic computational steps necessary to carry out, in principle, any quantum computation. The team has thus demonstrated that its architecture could, in principle, be suitable as a freely programmable quantum computer.
However, there is still a long way to go before we have a powerful and reliable quantum computer for research and industry. The new approach from Zurich, however, points to a possible direction: Mechanical vibrations could help make quantum computers more compact and powerful in the future.
Publication:
Yang, Y., Kladarić, I., Skrabulis, M., Eichenberger, M., Marti, S., Storz, S., Esche, J., García Bellés, R., Kern, M.-E., Omahen, A., Brooks, A., Bild, M., Fadel, M., & Chu, Y. (2026). Mechanical resonator–based quantum computing. Science, 392, 972–976.DOI:10.1126/science.aef4139
Source: ETH Zurich
Advantech
Edge AI HPCs for Vision AI and GenAI
Advantech has announced the 'AIR-410' and 'AIR-420', next-generation compact Edge AI high performance computers (HPCs). Combining AMD Ryzen 7000/8000/9000 series processors, scalable GPU support and Advantech's 'Edge AI SDK' software, the systems...
Neuron Automation
Functional Safety - Works!
With the certified safety modular system from Neuron Automation, OEMs can implement functionally safe control solutions faster, more flexibly and more cost-effectively - from hardware and firmware to the application. Functional safety 'in time', 'in...
