Sensor modules
Quelle: Sigmatek | Inka Krischke,
Precisely determine position and inclination
Sigmatek is expanding its 'S-Dias' portfolio with the BC 031 gyroscope sensor module, which provides rotation rate and linear acceleration information in three axes, enabling position and inclination to be determined precisely at any point in time.
© Sigmatek
Based on a MEMS sensor, the module ensures high-precision rotation rate measurement, according to the manufacturer. The acceleration resolution is 0.061 mg/LSB and the rotation rate resolution is 4.375 mdps/LSB. The module delivers reliable measurement results even in harsh environments - with strong shocks and vibrations. The high-resolution sensor module has a microcontroller for filtering the raw data. An Ethernet and RS485 interface are also integrated for reading in laser sensors from Sick, for example. The 'BC 031' is used in applications where the precise measurement of acceleration or rotary movements is required - in particular, for example, in automated guided vehicles (AGVs), logistics, lifting platforms or industrial robots.
Cable carriers
Use on deep drilling rigs
Deep drilling rigs with top drive systems are used to extract oil from the earth. Until now, manufacturers and operators have relied on so-called 'service loops' to feed cables to the systems. Now there is a new solution from Igus.
Cable glands
Plug-in and screw-on variants
Icotek has expanded the QVT-Click cable gland product family to include metric sizes 16 and 20, which are pluggable and screwable. The series is suitable for introducing pre-assembled cables and, according to the manufacturer, offers a compact and...
Industrial housing
Three aluminum series
Rose manufactures three aluminum enclosure series, each developed for specific applications and made from the cast aluminum alloy AC-AlSi 12 (Fe). External mounting channels protect the electronics in the housing from chips.
Adapter
Cables and wires well protected
Fränkische Industrial Pipes is launching the Fiplock One Aspa-HV termination, pull-in and suspension adapter. The closed adapter is mounted on the end of the Fiplock corrugated conduit and protects cables/lines inside from dirt and mechanical...
