Cable glands
Quelle: Icotek | Inka Krischke,
Plug-in and screw-on variants
Icotek has expanded the QVT-Click cable gland product family to include metric sizes 16 and 20, which are pluggable and screwable. The series is suitable for introducing pre-assembled cables and, according to the manufacturer, offers a compact and flat design.
© Icotek
If there is a lack of space on the inside of an enclosure, the series can be snapped in from the front of an enclosure. Thanks to the divisibility of the system, retrofitting and service work can be carried out without any problems. A new feature is the rounded bottom edges. The cable glands 16 and 20 are suitable for wall thicknesses of 1.5 to 2.5 mm. Cable grommets from the manufacturer are available for cables with a diameter of 1 to 15 mm and are inserted into the QVT-Click frames. Certifications such as HL3, ECOLAB, RoHs and others have been granted.
Cable carriers
Use on deep drilling rigs
Deep drilling rigs with top drive systems are used to extract oil from the earth. Until now, manufacturers and operators have relied on so-called 'service loops' to feed cables to the systems. Now there is a new solution from Igus.
Industrial housing
Three aluminum series
Rose manufactures three aluminum enclosure series, each developed for specific applications and made from the cast aluminum alloy AC-AlSi 12 (Fe). External mounting channels protect the electronics in the housing from chips.
Adapter
Cables and wires well protected
Fränkische Industrial Pipes is launching the Fiplock One Aspa-HV termination, pull-in and suspension adapter. The closed adapter is mounted on the end of the Fiplock corrugated conduit and protects cables/lines inside from dirt and mechanical...
