Round plug
Quelle: Provertha Connectors, Cables & Solutions | Inka Krischke,
Specified according to Profinet guidelines
Provertha has expanded its range of M8/M12 circular connector solutions and now also offers M8 crimp CF connectors with 360° shielding with D-code in protection class IP67.
© Provertha Connectors, Cables & Solutions
The 4-pin M8 connectors are specified by the Profibus User Organization (PNO) in accordance with the Profinet guidelines and enable robust and space-saving solutions for Profinet and Ethernet networks. In particular, the requirements for a functionally reliable Ethernet connection and interference-free data transmission in applications with high levels of vibration and torsion, such as in railroad and transportation technology as well as in factory automation for automatic punching presses and robot applications, are met. Thanks to its compact full metal housing, the connector is protected against interference in harsh environments. The turned crimp contacts ensure a high level of network security and the plastics used are certified for railroad applications in accordance with EN 45 545-2. Other features include a rated current of 4 A, a rated voltage of 60 V(DC), an insulation resistance of ±100 MΩ, a conductor cross-section of AWG 26 to 22 and cable diameters of 4.5 to 6.9 mm. The connectors work at temperatures from -20 to +85 °C.
Fischer Connectors
Layer by layer
In the course of the growing demands on data communication in the IoT age, the connector geometry, among other things, must be rethought when assembling high-speed connectors for an optimal energy flow. What needs to be taken into account?
Cable carriers
Use on deep drilling rigs
Deep drilling rigs with top drive systems are used to extract oil from the earth. Until now, manufacturers and operators have relied on so-called 'service loops' to feed cables to the systems. Now there is a new solution from Igus.
Cable glands
Plug-in and screw-on variants
Icotek has expanded the QVT-Click cable gland product family to include metric sizes 16 and 20, which are pluggable and screwable. The series is suitable for introducing pre-assembled cables and, according to the manufacturer, offers a compact and...
Industrial housing
Three aluminum series
Rose manufactures three aluminum enclosure series, each developed for specific applications and made from the cast aluminum alloy AC-AlSi 12 (Fe). External mounting channels protect the electronics in the housing from chips.
Adapter
Cables and wires well protected
Fränkische Industrial Pipes is launching the Fiplock One Aspa-HV termination, pull-in and suspension adapter. The closed adapter is mounted on the end of the Fiplock corrugated conduit and protects cables/lines inside from dirt and mechanical...
