Industrial housing
Quelle: Rose Systemtechnik | Inka Krischke,
Three aluminum series
Rose manufactures three aluminum enclosure series, each developed for specific applications and made from the cast aluminum alloy AC-AlSi 12 (Fe). External mounting channels protect the electronics in the housing from chips.
© Rose System Technology
The standard aluminum enclosures are particularly suitable for mechanical engineering and automation technology. They offer mounting options for mounting rails and mounting plates and can be used in a temperature range between -60 and +130 °C. The enclosures have protection class IP66 and are impact-resistant up to a load of 7 J. The enclosures are available in dimensions from 45 mm x 50 mm x 30 mm to 600 mm x 5600 mm x 202 mm. The Aluform enclosures with a flat housing shape and rounded cover bevels are frequently used in I&C and automation technology, particularly for customer-specific visualization and input solutions. They enable the simple installation of PCBs and circuit boards and do not require any additional processing. The enclosures are available in 15 sizes. The AluFormPlus series has been specially designed for the measurement and control technology sector. The enclosures are particularly suitable for mounting PCBs and can be fitted with a recessed cover to enable the installation of touch units. Thanks to protection class IP67/69, environments with demanding media such as moisture or vapors are no problem. The enclosures have a lid hinge for convenient handling and are available in eight sizes.
Cable carriers
Use on deep drilling rigs
Deep drilling rigs with top drive systems are used to extract oil from the earth. Until now, manufacturers and operators have relied on so-called 'service loops' to feed cables to the systems. Now there is a new solution from Igus.
Cable glands
Plug-in and screw-on variants
Icotek has expanded the QVT-Click cable gland product family to include metric sizes 16 and 20, which are pluggable and screwable. The series is suitable for introducing pre-assembled cables and, according to the manufacturer, offers a compact and...
Adapter
Cables and wires well protected
Fränkische Industrial Pipes is launching the Fiplock One Aspa-HV termination, pull-in and suspension adapter. The closed adapter is mounted on the end of the Fiplock corrugated conduit and protects cables/lines inside from dirt and mechanical...
