Network relay
Quelle: Wiesemann & Theis | Inka Krischke,
For load currents up to 16 A
Wiesemann & Theis is expanding its range of network-based 230 V remote switches to include two products with potential-free normally open and changeover contacts for load currents of up to 16 A.
© Wieseman & Theis
The Web-IO 4.0 230V relay 1xNO, 1xCO switches one NO and one changeover contact up to 16 A each. The 'big brother' - the Web-IO 4.0 230V relay 4xNO, 4xCO - switches four NO contacts and four changeover contacts with up to 6 A per channel. The industrial-grade network relays, which can be installed on a 35 mm top-hat rail, can be queried and controlled via the network. In addition to the web interface and apps for iOS and Android, various communication protocols are available for data access: Modbus/TCP, OPC, MQTT and REST support integration into Industry 4.0 and SCADA applications. Integration into any other network products is possible via TCP, UDP, SNMP and FTP. According to the provider, the Web-IOs meet high security requirements. The individual network services can be activated independently of each other. For each operating mode, it is possible to specify which outputs may be switched. An overview page provides information about active services and assigned channels. Access to the web interface and the sending of emails can be TLS-encrypted on request.
Cable carriers
Use on deep drilling rigs
Deep drilling rigs with top drive systems are used to extract oil from the earth. Until now, manufacturers and operators have relied on so-called 'service loops' to feed cables to the systems. Now there is a new solution from Igus.
Cable glands
Plug-in and screw-on variants
Icotek has expanded the QVT-Click cable gland product family to include metric sizes 16 and 20, which are pluggable and screwable. The series is suitable for introducing pre-assembled cables and, according to the manufacturer, offers a compact and...
Industrial housing
Three aluminum series
Rose manufactures three aluminum enclosure series, each developed for specific applications and made from the cast aluminum alloy AC-AlSi 12 (Fe). External mounting channels protect the electronics in the housing from chips.
Adapter
Cables and wires well protected
Fränkische Industrial Pipes is launching the Fiplock One Aspa-HV termination, pull-in and suspension adapter. The closed adapter is mounted on the end of the Fiplock corrugated conduit and protects cables/lines inside from dirt and mechanical...
