Labeling
Quelle: ZVK | Inka Krischke,
Order in the data center
EasyLan, the brand of ZVK, an OEM manufacturer and developer of pre-assembled copper and fiber optic cables, now offers individual labeling for the majority of its products.
© ZVK
Enclosures, panels, cables, boxes, outlets, distribution systems or assemblies can be permanently labeled to avoid confusion. Seven standard size formats are available for the labeling strips, which can be applied ex works as an option, to identify the location (room, rack, floor or building wing), functional or data information of the carrier, for example.
Cable carriers
Use on deep drilling rigs
Deep drilling rigs with top drive systems are used to extract oil from the earth. Until now, manufacturers and operators have relied on so-called 'service loops' to feed cables to the systems. Now there is a new solution from Igus.
Cable glands
Plug-in and screw-on variants
Icotek has expanded the QVT-Click cable gland product family to include metric sizes 16 and 20, which are pluggable and screwable. The series is suitable for introducing pre-assembled cables and, according to the manufacturer, offers a compact and...
Industrial housing
Three aluminum series
Rose manufactures three aluminum enclosure series, each developed for specific applications and made from the cast aluminum alloy AC-AlSi 12 (Fe). External mounting channels protect the electronics in the housing from chips.
Adapter
Cables and wires well protected
Fränkische Industrial Pipes is launching the Fiplock One Aspa-HV termination, pull-in and suspension adapter. The closed adapter is mounted on the end of the Fiplock corrugated conduit and protects cables/lines inside from dirt and mechanical...
