Cable entry plates
Suitable for sheet thicknesses from 1.5 to 2.5 mm
Icotek is expanding its range of tool-free mountable cable entry plates with the KEL-DP 6 and KEL-DP 16. They are suitable for sheet thicknesses from 1.5 to 2.5 mm and are available in round, square and narrow designs to fit standard standard cut-outs.
The 'KEL-DP 6' size is based on the cut-out of the 6-pin connector measuring 36 mm x 52 mm; the 'KEL-DP 16' is based on the cut-out of the 16-pin connector measuring 36 mm x 86 mm. It can be used to feed through up to 23 cables, with the 'KEL-DP 6' the maximum is 25. A panel is fitted by pressing it into the punched-out frame. The position of the plate is also centered by the integrated spring bars. The cable entry plates achieve protection class IP64.
