Adapter
Cables and wires well protected
Fränkische Industrial Pipes is launching the Fiplock One Aspa-HV termination, pull-in and suspension adapter. The closed adapter is fitted to the end of the Fiplock corrugated conduit and protects cables/lines inside from dirt and mechanical influences, for example.
An eyelet at the connection end of the adapter allows the sensitive cables bundled in the corrugated conduit to be suspended from a hook or similar device for transportation. Alternatively, the hole can be connected to a pull-in cable to pull the preassembled corrugated conduit into a system or install it.
Aspa-HV meets all protection classes from IP66 to IP69, is classified in fire class V0 and fire hazard level HL3, is self-extinguishing and does not spread fire. The adapter fits all corrugated conduits with nominal widths of 23 and 36 and with a fine (F) or coarse (C) profile. It is made of modified PA6 and can withstand temperatures from -50 to +120 °C.
