Cable carriers
Quelle: Igus | Inka Krischke,
Use on deep drilling rigs
Deep drilling rigs with top drive systems are used to extract oil from the earth. Until now, manufacturers and operators have relied on so-called 'service loops' for the cable feed of the systems. Now there is a new solution from Igus.
© Igus
With 'service loops', the cables have no guidance, they do not have a defined bending radius and, in the worst case, they can break when moving. Igus has developed the e-loop energy chain so that cables with large cross-sections and high weights can be safely guided in suspended applications: This is a round, three-dimensional modular system that can move cables with a defined bending radius in a strain-relieved manner. The modular energy chain can be opened from the outside and continuously filled. The links can be replaced at any time. Multiple secured screw connections are used between the elements of the cable carrier to prevent components from falling down. As deep drilling rigs have to change their location regularly, the chain has bolted connection elements that enable quick disassembly. In addition to use on deep drilling rigs, the saltwater-resistant 'e-loop' is suitable for suspended applications in the offshore industry, for construction machinery, shore power or wind turbines. High vibrations, lateral impacts and shocks cannot harm the system. The cable carrier is built around a high-tensile plastic cable that absorbs the tensile forces of the cables. The cable is made of a synthetic plastic fiber and is therefore unbreakable, weather-resistant, flexible and corrosion-free. The cable carrier can bear weights of up to 220 kN with the cable.
Igus
Vector Award presented
Every two years, Igus presents the Vector Award to recognize exciting and creative energy chain applications. This year, 266 applications from 32 countries were received. The winners have now been chosen.
Low cost robotics
Igus announces 'ROIBOT Award
The 'ROIBOT Award', which Igus is presenting for the first time, is intended to recognize clever applications with a quick return on investment based on cost-effective robot technology from the Cologne-based company. Interested parties can register...
Cable glands
Plug-in and screw-on variants
Icotek has expanded the QVT-Click cable gland product family to include metric sizes 16 and 20, which are pluggable and screwable. The series is suitable for introducing pre-assembled cables and, according to the manufacturer, offers a compact and...
Industrial housing
Three aluminum series
Rose manufactures three aluminum enclosure series, each developed for specific applications and made from the cast aluminum alloy AC-AlSi 12 (Fe). External mounting channels protect the electronics in the housing from chips.
