I/O modules
Quelle: Weidmüller Interface | Inka Krischke,
Channels can be parameterized as input or output
UR20-8DIO-P-3W-Diag from Weidmüller complements the supplier's 'u-remote' family. With the universal, digital I/O module, each individual channel can be parameterized independently as an input or output.
© Weidmüller Interface
On the one hand, this offers the advantage that both sensors and actuators can be connected to just one module, thus reducing the number of modules in the I/O station. On the other hand, subsequent changes to the automation can be carried out without major effort by reconfiguring, for example if an actuator is to be removed and an additional sensor installed instead. If only a small number of digital sensors or actuators are used, these can now be integrated into the automation system via a single module. This saves space in the control cabinet and reduces the costs and effort involved in planning, ordering, warehousing and commissioning.
Cable carriers
Use on deep drilling rigs
Deep drilling rigs with top drive systems are used to extract oil from the earth. Until now, manufacturers and operators have relied on so-called 'service loops' to feed cables to the systems. Now there is a new solution from Igus.
Cable glands
Plug-in and screw-on variants
Icotek has expanded the QVT-Click cable gland product family to include metric sizes 16 and 20, which are pluggable and screwable. The series is suitable for introducing pre-assembled cables and, according to the manufacturer, offers a compact and...
Industrial housing
Three aluminum series
Rose manufactures three aluminum enclosure series, each developed for specific applications and made from the cast aluminum alloy AC-AlSi 12 (Fe). External mounting channels protect the electronics in the housing from chips.
Adapter
Cables and wires well protected
Fränkische Industrial Pipes is launching the Fiplock One Aspa-HV termination, pull-in and suspension adapter. The closed adapter is mounted on the end of the Fiplock corrugated conduit and protects cables/lines inside from dirt and mechanical...
