2D imager
Quelle: Datalogic Automation | Inka Krischke,
For OEM and entry level manufacturing
The Matrix 120 from Datalogic is a compact 2D imager with embedded Ethernet for industrial use. According to the provider, it covers all OEM and entry-level manufacturing applications with just a few models.
© Datalogic Automation
The polarized model can be installed at a 90° angle, which further reduces the space required for installation. The device offers an easy-to-use external focusing option that can be adapted to all reading conditions. All models can be used flexibly - from simple applications with standard codes to high-resolution codes or applications with linear barcodes. Protection class IP65 is fulfilled, the operating temperature is between 0 and 45 °C. A serial USB and Ethernet interface are integrated.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
