Analog modules
Channels can be parameterized individually
Wago is expanding the I/O system 750 with the 750-471 module with four electrically isolated analog inputs.
The galvanic isolation of signal inputs is particularly important in areas where interference can occur due to potential differences, for example in marine and offshore applications. The resolution of the analogue module's inputs is 16 bits. The channels can be parameterized individually, either as a current input from 0 to 20 mA, 4 to 20 mA, 3.6 to 21 mA (NE43) or ±20 mA or as a voltage input with the ranges 0 to 10 V, ±10 V and up to the mV range of ±200 mV. The user can parameterize the modules individually according to requirements and only needs one module to be able to record almost all analogue encoders.
