MES solutions
Quelle: MPDV Mikrolab | Lukas Dehling,
Test the services
© MPDV Microlab
The new Service Tester supports developers in testing the available services of the Hydra MES solution and generating code modules for their own applications with just a few clicks - regardless of whether they are original Hydra services or services developed in-house. To do this, the Service Tester accesses the REST-based service interface, which has been available to users for some time. According to the manufacturer, the Service Tester offers a clear user interface with many helpful functions as well as the option of batch operation - for example to automate tests.
Energy chains
Lying flat on its side
Raspberry Pi
Control cabinet wiring
Divide into sub-projects
Solution provider Eplan presents version 2.8 of Eplan Smart Wiring, which is designed to optimize the process of wiring control cabinets. The first key innovation, which also supports collaborative engineering, is the ability to divide projects into...
