Industrial PCs
Quelle: Noax Technologies | Lukas Dehling,
Can be operated with gloves
The new stainless steel industrial PC S21WR from Noax offers a 16:9 display and a safety touchscreen.
© Noax Technologies
It can be operated with gloves, objects or bare fingers; moisture, dirt and even drops of water cannot harm the device. The PC with the 21.5-inch full HD display is suitable for use in food production or in the smart factory, for example. Certified up to protection class IP69K, the closed, polished stainless steel housing of the industrial PC can be cleaned under high pressure and with aggressive chemical agents. The computer from the Steel series is available with various processors up to Intel Core i7. It also offers numerous standard interfaces and can be easily adapted to the existing production environment using PCI or PCIe cards. In order to integrate authentication processes into production workflows, the device can be equipped with RFID readers in various standards, such as Mifare and Legic.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
Control cabinet wiring
Divide into sub-projects
Solution provider Eplan presents version 2.8 of Eplan Smart Wiring, which is designed to optimize the process of wiring control cabinets. The first key innovation, which also supports collaborative engineering, is the ability to divide projects into...
