Energy chains
Quelle: Igus | Inka Krischke,
Lying flat on its side
© Igus
The convex trough shape of the trough allows the 'Series E6' energy chain to travel safely in two recessed channels. The stainless steel trough with its low friction factor also ensures a long service life for the chain. A special plastic insulating layer can be used on the outside of the channel to provide additional noise insulation for the system. Thanks to the lightweight components, the energy chain solution can be easily mounted under the ceiling of gantry robots, for example. At the customer's request, 'plane-chain' is also available completely enclosed so that no objects can penetrate from outside.
MES solutions
Test the services
Raspberry Pi
Control cabinet wiring
Divide into sub-projects
Solution provider Eplan presents version 2.8 of Eplan Smart Wiring, which is designed to optimize the process of wiring control cabinets. The first key innovation, which also supports collaborative engineering, is the ability to divide projects into...
