Router
Certified for Microsoft Azure IoT
In addition to the certification of the LTE router MRO-L200 from Insys icom, the basic variants (DSL, LTE, LAN) of the modular industrial router series MRX are Microsoft Azure certified for IoT.
The routers are pre-tested and verified to work with Microsoft Azure IoT services so that IoT solutions can be implemented quickly. The certified MRX3 and MRX5 router series capture data from a wide range of applications, regardless of protocols and manufacturers. By verifying the routers as 'Microsoft Azure Certified for IoT', direct coupling with Microsoft Azure projects via MQTT is possible. The MRX router series is based on a fully modular platform. The basic LAN, DSL and LTE variants are available in two housing widths with three or five slots. Expansion cards (MRcards) supplement the basic variants with selected modules such as serial ports, digital I/Os, Ethernet switch, VDSL/ADSL or LTE.
