Panel PCs
Quelle: Distec | Lukas Dehling,
Compatible with the Raspberry Pi
Distec is showing the new IoT-capable POS-Line IoT monitor, which is based on the newly developed Artista-IoT controller board that integrates the latest generation of the Raspberry Pi compute module (CM3).
© Distec
The Artista-IoT controller card offers comprehensive functionality with direct control, 100 Mbit Ethernet, real-time clock and special functions such as DICOM pre-set, gamma correction and color calibration. The available interfaces include USB, GPIOs, I²C and UART. According to the manufacturer, compatibility with the Raspberry Pi offers broad support from a large developer community for further development and integration. The company offers a starter set consisting of BaseBoard, CM3, 10.1-inch display with PCAP multi-touch and all necessary cables. The POS-Line-IoT series monitor or panel PC is therefore suitable for cost-efficient IoT applications in industry and digital signage.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
