VEGA
Clear control of the process statuses
A new generation of control units from Vega simplifies level and pressure measurement. With the high-contrast display of the Vegamet series, all options for clear visualization of measurement data are available.
© VEGA
The large display diagonal in relation to the small design provides an overview - even from a distance and in bright daylight. The control units can be operated via Bluetooth using a smartphone or tablet. This allows devices to be parameterized remotely and measured values to be monitored outside danger zones. In outdoor areas, a suitable sunshield on the 'Vegamet 800' devices ensures reliable readability in direct sunlight.
To protect the Vega device from vandalism and prying eyes, the display can be switched off automatically after two minutes if required. The 'Vegamet' 140, 340 and 800 series are also suitable for complex tasks such as pump controls, flow measurements, totalizers, data loggers or differential, total and average value calculations.
Vega
Select process connections as required
Vega's 'Vegabar' pressure sensors and 'Vegapoint' point level switches were to be the protagonists at this year's SPS, as they made Vega a full-service provider for level and pressure in food and pharmaceutical processes at the beginning of 2020.
Hexagon
Modular blue laser line scanner
Hexagon Manufacturing Intelligence introduces the 'Absolute Scanner AS1' with an automatable data capture rate of 1.2 million points per second and interoperability between mobile measuring arm and laser tracker systems.
Vega
No need for cabling
Vega is launching the self-sufficient 'Vegapuls Air' radar sensors on the market in early 2021. Product Manager Clemens Hengstler explains what makes them so special.
Vega
Sensor portfolio completed
With the Vegabar pressure sensors and Vegapoint point level switches, Vega has become a full-range supplier for level and pressure in food and pharmaceutical processes.
