Vega
Limit switch masters sticky and viscous substances
Vega has developed the flush-mounted Vegapoint 24 point level switch especially for use with highly sticky, viscous or abrasive media. Even with the strongest build-up, it reliably detects the coverage status and indicates it with a colored illuminated ring.
© Vega
Many food and pharmaceutical products have a distinctive texture. Depending on the consistency, the demands on the level measurement technology used in production increase. The Vegapoint 24 is a genuine plug & play sensor. It can be installed in just a few simple steps. Flexible production systems with frequent and fast product changes benefit from the fact that it detects all media using the factory setting without adjustment. Advanced functions such as interface detection or foam suppression can also be easily configured.
With this sensor,Vega is specifically targeting the beverage, food and pharmaceutical sectors. The flush-mounted design of the sensor in particular ensures universal application possibilities. With its wide range of process connections and adapters, the point level switch can also be easily integrated into existing systems.
Vega
Select process connections as required
Vega's 'Vegabar' pressure sensors and 'Vegapoint' point level switches were to be the protagonists at this year's SPS, as they made Vega a full-service provider for level and pressure in food and pharmaceutical processes at the beginning of 2020.
Vega
No need for cabling
Vega is launching the self-sufficient 'Vegapuls Air' radar sensors on the market in early 2021. Product Manager Clemens Hengstler explains what makes them so special.
Vega
Sensor portfolio completed
With the Vegabar pressure sensors and Vegapoint point level switches, Vega has become a full-range supplier for level and pressure in food and pharmaceutical processes.
Vega Grieshaber
Chip start-up founded
The start-up milli IC from Karlsruhe specializes in the development of ASICs - and Vega Grieshaber is 'on board' to ultimately develop radar measuring devices with radar frequencies of more than 100 GHz.
Vega
Level measurement under extreme temperatures
Vega's high-temperature version of the 'Vegapuls 6X' radar sensor is suitable for processes at temperatures of up to +450 °C, such as iron briquetting, in which porous sponge iron mass passes through heat-resistant roller presses at temperatures of...
