Data module
Can be used from -20 to +80 °C
Data Modul is expanding its display portfolio with an industrial 21.5-inch high-brightness display for the extended temperature range.
As a semi-outdoor display, it is particularly suitable for applications in the field of digital signage, vending machines and HMI applications in industrial use. According to Data Modul, the display with the designation G215HVN01.3 has a brightness of 1000 cd/m2 and can be used in a temperature range between -20 and +80 °C. With a resolution of Full HD (1920x1080), a contrast ratio of 5000:1 and MVA technology, it offers a rich image from any viewing angle, according to the manufacturer.
The model complements the standard 'G215HVN' series, which delivers a brightness of 250 to 300 cd/m2 and has been designed for temperatures from 0 to +60 °C. As the series has the same form factor, a simple mechanical change between the models is possible.
