Hesch
Incorrect measurements excluded
The HE 5422 differential pressure regulator from Hesch has been redesigned: Thanks to the pre-coating functionality, the cleaning process is significantly simplified and the Datahold function eliminates incorrect measurements.
© Hesch
The regulator can be operated intuitively and is easier to maintain thanks to the new hinge technology. The regulator can be used to measure differential pressure ranges from +-2.5 to +-1000 mbar. The redesign also makes configuring the differential pressure regulator more convenient: with the 'Easy Tool Controls' software in version 4.0, the regulator can be parameterized not only directly on the device, but also via PC or notebook. For this purpose, the integrated service interface (USB/B) can be upgraded with a USB/TTL adapter.
The operating range of the controller is defined via two alarm limit contacts (lower/upper threshold).
Janitza electronics
Say goodbye to load peaks
Peak loads are expensive. Even one-off 'slips' cause additional costs in the five-figure range. However, the obvious solution of temporarily switching off large consumers such as heating systems must not compromise process reliability. Modern...
Manner sensor telemetry
Two into one
Manner offers the XtreMA two-in-one dual-range torque transducer for recording multiple rotating torque ranges. This transducer has two torque ranges with two separate and independent signal outputs.
Endress+Hauser
Measuring gas made easy
The Prosonic Flow G300/500 ultrasonic flowmeter from Endress+Hauser is used for gas measurement. Thanks to the condensate-insensitive sensor design, the device delivers highly accurate measured values even with moist or wet gases, according to the...
