Endress+Hauser
Measuring gas made easy
The Prosonic Flow G300/500 ultrasonic flowmeter from Endress+Hauser is used for gas measurement. Thanks to the condensate-insensitive sensor design, the device delivers highly accurate measured values even with moist or wet gases, according to the supplier.
The integrated pressure and temperature measurement minimizes the installation effort, and the multi-parameter measurement allows both mass and standard volume to be measured and output directly. The integrated gas analysis function also makes it possible to calculate the calorific value, energy flow, molar mass, density and viscosity, for example.
The flowmeter is SIL-certified and, together with 'Heartbeat Technology', offers traceable device verification without interrupting the process.
