Manner sensor telemetry
Two into one
Manner offers the XtreMA two-in-one dual-range torque transducer for recording multiple rotating torque ranges. This transducer has two torque ranges with two separate and independent signal outputs.
© Manner sensor telemetry
Both the nominal and the spread measuring range are optimized in terms of accuracy. Two calibrations and corresponding calibration protocols are created for the transducer for evaluation. Both the zero point drift Tk0 and the characteristic drift Tkc are minimized via the temperature on the respective measuring range. Users can decide which channel is used for the corresponding measurement task.
According to the manufacturer, the tasks of nominal torque acquisition and friction power measurement can be carried out with one measuring device without any modifications to the drive train. Thanks to the overload design of 400 %, the torque sensor offers both the measurement of continuous loads and the short-term detection of load peaks in dynamic operation. The associated stator unit in tube design allows the output of digital signals via Ethercat, CAN, Ethernet or USB in addition to the classic analog signals.
Hesch
Incorrect measurements excluded
The HE 5422 differential pressure regulator from Hesch has been redesigned: Thanks to the pre-coating functionality, the cleaning process is significantly simplified and the Datahold function eliminates incorrect measurements.
Janitza electronics
Say goodbye to load peaks
Peak loads are expensive. Even one-off 'slips' cause additional costs in the five-figure range. However, the obvious solution of temporarily switching off large consumers such as heating systems must not compromise process reliability. Modern...
Advertorial
Drive systems taken further
A FAULHABER drive system is more than the sum of its components. When users combine products with each other, the overall performance of the system increases. Experience the FAULHABER principle of perfectly optimized parameters and interfaces for...
AMA Innovation Award 2025
Submit applications now
The AMA Association for Sensors and Measurement (AMA) is calling on scientists and developers from industry and research to apply for the AMA Innovation Award 2025. We are looking for research and development results in sensor and measurement...
