Labom
Differential pressure transmitter with rotatable display
Labom has added a new device to the 'V-Line': the Pascal CV4 Delta P CV 4300 is a flexible digital differential pressure transmitter that has numerous functions despite its compact size
© Labom
Its stainless steel housing complies with protection class IP65 or IP67 (optional IP69K), the electrical connection can be rotated continuously by 170° in relation to the process connection. The high-resolution display can also be rotated, allowing it to be aligned specifically to the operator. Intuitive 4-button user guidance and freely configurable display modes contribute to user-friendliness. The display can also be removed under voltage.
The differential pressure transmitter is used for level measurement in pressure vessels and for monitoring filters in process engineering, the chemical/petrochemical industry and in mechanical and plant engineering.
According to the supplier, the nominal range is between 0.25 and 40 bar with an accuracy of 0.15 %. The output signal is 4 to 20 mA with HART protocol.
AMO
Operating cobots safely
AMO's measuring devices measure position values with deviations of less than 1 µm per signal period, which enables precise positioning of robot axes and thus the safe operation of cobots in close proximity to human workers.
Janitza electronics
Say goodbye to load peaks
Peak loads are expensive. Even one-off 'slips' cause additional costs in the five-figure range. However, the obvious solution of temporarily switching off large consumers such as heating systems must not compromise process reliability. Modern...
Manner sensor telemetry
Two into one
Manner offers the XtreMA two-in-one dual-range torque transducer for recording multiple rotating torque ranges. This transducer has two torque ranges with two separate and independent signal outputs.
Endress+Hauser
Measuring gas made easy
The Prosonic Flow G300/500 ultrasonic flowmeter from Endress+Hauser is used for gas measurement. Thanks to the condensate-insensitive sensor design, the device delivers highly accurate measured values even with moist or wet gases, according to the...
