Drive programming
Without external control
With the drive-based 'Sequential Motion Control SMC' function, users can reduce programming and commissioning time by up to 90 % compared to classic PLC automation, according to supplier Bosch Rexroth.
Topics and products in this article
Is your company active in these markets/areas?
More responsive real-time display
Dassault Systèmes offers new technologies and workflows with Solidworks 2019 to improve collaboration and enable immersive, interactive experiences during design and engineering.
Test the services
Channels can be parameterized individually
Wago is expanding the I/O system 750 with the 750-471 module with four electrically isolated analog inputs.
Lying flat on its side
For computationally intensive AI applications
Kontron is expanding its rackmount server product portfolio with the Kiss 4U V3 SKW in 4U format. It offers high performance, more storage capacity for high-performance image processing, compute-intensive AI and machine learning applications and...
Control up to four valves simultaneously
Precise dosing, for example for adhesive or liquid applications, requires equally precise control of valves. The 'S-Dias' CO 041 module from Sigmatek offers four current-controlled PWM outputs for this purpose.
Distances of 100 meters possible
B&R has introduced the fourth generation of Smart Display Link (SDL) display transmission technology. SDL4 is based on HDBaseT 2.0.
Can be operated with gloves
The new stainless steel industrial PC S21WR from Noax offers a 16:9 display and a safety touchscreen.
