PLC analyzer
Quelle: GWT-TUD | Inka Krischke,
Support for the TIA portal
The AutoSPy analyzer is a tool for the rapid acquisition and evaluation of process data for fault diagnosis or optimization of automation systems.
© GWT-TUD
With its driver for Simatic S7-1200/1500 PLCs, it offers full support for the Step 7 TIA portal. The driver enables precise signal acquisition from a maximum of 16 PLCs simultaneously, with a freely adjustable sampling rate and without intervention in the PLC program. The signals can be selected directly from the PLC variables of the Step 7 TIA Portal projects; an additional export/import step is not necessary. Users do not have to switch off the optimized block access for the S7 data blocks or activate the insecure put/get communication between PLC and PC. Special configuration of the PLCs, as required by other error diagnosis programs, is not necessary.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
