COM Express modules
Quelle: Portwell Deutschland | Lukas Dehling,
Intel Gen9 graphics processor integrated
Portwell presents the PCOM-B641VG, a COM Express Type 6 module in compact format (95 mm × 95 mm) based on the new 14 nm Intel Atom processor E3900 product family (6 W ~ 12 W).
© Portwell Germany
According to the manufacturer, the module offers around 30% better overall performance than its predecessor. It includes the Intel Gen9 graphics processor with higher media performance, accelerated DRM (Digital Rights Management) for encoding and decoding media content and a wide range of I/O interfaces. The COM Express Type-6 standard allows the performance and longevity of existing COMe system solutions to be improved by simply replacing the CPU module. This increases system availability by a further seven years and maximizes system profitability. The module supports up to 32 GByte DDR3L 1600/1866 MT/s SDRAM on two 204-pin SODIMM slots. A maximum of four PCI Express x1 Gen2 (5.0GT/s) bus interfaces are supported for fast I/O cards or I/O devices. For more flexibility, these can be configured as two x2 lanes or one x4 lane for higher data throughput. It also supports three independent display interfaces: DisplayPort/HDMI, VGA and LVDS.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
