Panel PCs
Quelle: TL Electronic | Lukas Dehling,
Completely scalable
The G-Win series from TL Electronic can be flexibly scaled by the user from a range of display sizes and types, processors, equipment features and I/O options.
© TL Electronic
According to the manufacturer, the range and modular design of the panel PCs with IP65 to IP67 protection simplifies configuration for stationary and vehicle-mounted applications. Both projected capacitive multi-touch fronts and more cost-effective 5-point resistive touchscreens in seven diagonals from 17.8 cm (7 inches) to 48.3 cm (19 inches) are available for the operating unit. The range of processors extends from the Freescale Cortex A9 i.MX 6 quad-core to Intel's Celeron N2930 and Core i5 5200U. The G-Win series operates without a fan in a wide temperature range from -25°C to +60°C. The Panel PCs meet the MIL-STD-810 military standard for shock and vibration resistance. Various waterproof connection cables are available directly from TL Electronic for the all-round IP65-protected devices.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
