Profibus DP Master
Quelle: Softing Industrial Automation | Inka Krischke,
Solution for FPGAs from Xilinx
With the Profibus DP Master for FPGAs from Xilinx, Softing is expanding its range of loadable logic with integrated protocol software for industrial communication protocols.
© Softing Industrial Automation
The offering complements the family of FPGA-based fieldbus and industrial Ethernet implementations for field devices and controller applications. The Profibus master is now also available for Xilinx FPGAs in addition to the solution for Altera FPGAs. This allows users to choose the FPGA provider according to their requirements and use the development environment they are familiar with. The complete protocol software is already executable on the processor contained in the IP core. This means that users do not have to perform any porting, but can concentrate directly on application development, which is supported by sample projects on common evaluation hardware. Thanks to the implementation in the FPGA, there is no dependency on the availability of classic communication modules. Instead, the user selects the most suitable FPGA family and size for their product, in which the communication subsystem can then be used unchanged.
Texas Instruments
Ethernet with 4 µs
Previous Industrial Ethernet protocols allow cyclical communication with field devices in the two- or three-digit microsecond range. Texas Instruments now wants to push this limit significantly lower.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
