Power supplies
Quelle: Bender | Inka Krischke,
Insights into the electrical installation
Bender will be presenting the web-based Powerscout software and residual current monitoring in a live demonstration.
© Bender
The software gives visitors to SPS IPC Drives 2017 a direct insight into the electrical installation at NürnbergMesse on a large screen, allowing them to find out directly about its status. Powerscout brings together all stored data from the measuring and monitoring equipment installed there and creates visualizations, evaluations and user-specific reports of all important measured values. This allows faults to be detected at an early stage and their causes eliminated promptly before damage or system failures occur. This continuous monitoring not only ensures a reliable power supply, but also offers the operator predictive maintenance.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
