Cable entries
Tool-free assembly
Icotek introduces the tool-free cable entry of the KEL-Quick series. The cable entry strip is a system for inserting and sealing pre-assembled cables, hoses and pneumatic lines.
The previously common slotted grommets from the manufacturer of the 'QT' series are used. One new feature is the end cover on the head side, which is snapped onto the assembled frame. The series is based on cut-outs for 24/16/10-pin heavy-duty connectors as well as cut-outs measuring 36 mm × 46 mm. Tool-free assembly is carried out either by screwing on or by snapping into the 'KEL-Snap' frame. The 'KEL-Quick-E' is also available as a single-row variant. The series is tested to IP54 and UL, among others.
