Illuminated pushbutton
Quelle: Rafi | Inka Krischke,
Tactile feedback in a harsh environment
Rafi is expanding the 'Ramo' range with the Ramo T actuator with tactile feedback and Ramo I LED signal lights.
© Rafi
Both model series have a low installation height for standardized installation openings of 22.3 mm and 30.3 mm and are designed to match the 'Rafix' range of control devices. The manufacturer has equipped its 'Ramo 22/30 T' pushbuttons with the short-stroke technology of the Micon 5 series, including gold contacts, for a clearly audible click. Developed as standard components for plant engineering, for example, the Ramo T reliably acknowledges the input with its tactile feedback. Their fully enclosed mono housing with IP66/IP69K protection offers protection against dirt and humidity. The actuators are optionally equipped with four-pin M8 or M12 plug connections and can be connected without manual wiring using plug & play with straight or angled plugs. Ramo T is available in numerous versions with an illuminated push-button surface in different colors and a round or square collar. With 'Ramo 22/30 I', the company is also launching signal lights in the same design and form factor. The bright and energy-efficient LED lights achieve a beam and viewing angle of more than 180° thanks to their concave bezel.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
