Plug housing
Storage minimized
Thanks to its modular design, every connector housing from Hummel can be combined with numerous contact inserts so that users can realize almost any number of poles imaginable on the basis of one housing design.
For example, the M23 series offers solutions for signal, power and Industrial Ethernet - for applications in the signal segment alone, there are different housing designs in a total of 26 variants. These in turn can be fitted with ten different contact inserts. Pin and socket inserts are also interchangeable. The modularity minimizes stock-keeping, simplifies planning and assembly always follows the same principle. The connectors can be assembled and disassembled without special tools. The connectors are available both with a screw lock and with the 'Twilock' quick lock. Variants that are plug-compatible with the 'Speedtec' locking system are also available.
