EMC shielding clamps
Quelle: Icotek | Inka Krischke,
For screen diameters from 3 to 18 mm
With the 'Multi-Shielding Clamp MSKL' series, Icotek is launching a generation of EMC shielding clamps onto the market which, according to the supplier, can contact almost 90% of the shielded cables on the market with just two shielding clamp sizes.
© Icotek
The shield clamp has large clamping ranges and large-surface contacting of the cable shield with a narrow and low design. The MSKL 3-12 has a clamping range of 3 to 12 mm and the MSKL 8-18 has a clamping range of 8 to 18 mm. The shield clamps can be ordered loose or with different mounting brackets for direct screw mounting or for snapping onto a 35 mm top-hat rail. An integrated strain relief is available to further protect the system. Strain relief is provided via the outer cable sheath and not via the sensitive cable shield.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
