Adapter
Quelle: Fränkische Industrial Pipes | Inka Krischke,
Cables and wires well protected
Fränkische Industrial Pipes is launching the Fiplock One Aspa-HV termination, pull-in and suspension adapter. The closed adapter is fitted to the end of the Fiplock corrugated conduit and protects cables/lines inside from dirt and mechanical influences, for example.
© Franconian Industrial Pipes
An eyelet at the connection end of the adapter allows the sensitive cables bundled in the corrugated conduit to be suspended from a hook or similar device for transportation. Alternatively, the hole can be connected to a pull-in cable to pull the preassembled corrugated conduit into a system or install it.
Aspa-HV meets all protection classes from IP66 to IP69, is classified in fire class V0 and fire hazard level HL3, is self-extinguishing and does not spread fire. The adapter fits all corrugated conduits with nominal widths of 23 and 36 and with a fine (F) or coarse (C) profile. It is made of modified PA6 and can withstand temperatures from -50 to +120 °C.
Cable carriers
Use on deep drilling rigs
Deep drilling rigs with top drive systems are used to extract oil from the earth. Until now, manufacturers and operators have relied on so-called 'service loops' to feed cables to the systems. Now there is a new solution from Igus.
Cable glands
Plug-in and screw-on variants
Icotek has expanded the QVT-Click cable gland product family to include metric sizes 16 and 20, which are pluggable and screwable. The series is suitable for introducing pre-assembled cables and, according to the manufacturer, offers a compact and...
Industrial housing
Three aluminum series
Rose manufactures three aluminum enclosure series, each developed for specific applications and made from the cast aluminum alloy AC-AlSi 12 (Fe). External mounting channels protect the electronics in the housing from chips.
