Plug connector
Quelle: Binder | Lukas Dehling,
Available as cable and flange connectors
Binder is expanding the 'Harsh Environment Connector' (HEC) with a new mains connector: the 'Series 696' power connector.
© Binder
It is designed for up to 32 A at a rated voltage of 600 V and is available as a cable and flange connector with 4+PE silver contacts (plug or socket). Made of polyamide with UL-94V-0 classification, the connector is robust and can be attached quickly and securely thanks to its three-point bayonet locking system. A special coupling mechanism prevents misalignment. The mechanical service life is over 1000 mating cycles. According to the supplier, the use of different crimp contacts also ensures a secure, vibration-proof connection. The HEC 696 power and flange connector is dust-tight, protected to IP68/IP69k and can withstand rough treatment, for example in agriculture or the construction industry, where high-pressure cleaning is often used. Other areas of application include traffic and signaling systems, process engineering systems, water purification systems and recycling technology.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
