I/O distributor
Active logic function on board
Escha is launching new M8x1 I/O distributors with active logic function in different versions. The I/O distributors place intelligence close to sensors and transmit pre-processed signals to a central control unit.
Due to their compact design and low weight, the I/O distributors are particularly suitable for applications with limited space, such as grippers, robots or compact handling units. Several mounting holes allow the distributors to be mounted in different installation situations. Label holders on all slots facilitate marking and assignment. The M8x1 I/O distributors with active logic function are available in 4-slot, 8-slot and 10-slot versions with various fixed combinations of AND and OR logic. The fixed logic means that the distributors do not need to be programmed by the user and are immediately ready for use. A switching status display for each channel and an LED display for the logic output provide a quick overview of the most important functions. All distributors meet the IP65 and IP67 tightness requirements.
