Drive controller
Quelle: Kostal Industrie Elektrik | Inka Krischke,
Use under heavy-duty conditions
The 'Inveor' drive controller platform from Kostal can also be used in heavy-duty applications. Here, the function must be ensured under very high or very low temperatures as well as under very strong vibration.
© Kostal Industrie Elektrik
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
