Three-phase soft start control
Quelle: WEG Germany | Inka Krischke,
Integrated bypass contactor
The SSW900 soft starter, which will replace the previous 'SSW07' starter series from WEG, was developed for industrial and commercial use and covers output currents from 10 A to 412 A in the 220 to 575 V wide voltage range.
© WEG Germany
As a high-end device with an integrated PLC, it offers fully programmable procedures for controlling asynchronous motors and flexible torque control. Thanks to the integrated bypass contactor, the three-phase soft start control ensures an extended service life, optimized use of space and reduced heat dissipation in the control cabinet, according to the supplier. The user interface simplifies operation and enables users to make program adjustments quickly. The soft starter is suitable for applications such as fans/venting fans, axial, centrifugal and dosing pumps, agitators and mixers, conveyor belts, extruders, dryers and industrial ovens, rotary tables as well as ball and hammer mills.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
