DC servomotors
Quelle: Dr. Fritz Faulhaber | Günter Herkommer,
For highly dynamic applications
Faulhaber is expanding its portfolio of DC servomotors with the LM 1483 with a continuous force of 6.2 N and a peak force of up to 18.4 N. The motor measures 14 x 20 x 83 mm and has a rotor rod diameter of 6 mm.
© Dr. Fritz Faulhaber
It is available in various stroke lengths from 20 to 80 mm. In addition, the stainless steel slider rod is fitted with welded cover plates that provide a robust and reliable interface to the application. Thanks to the three integrated analog Hall sensors, the -11 version can be easily combined with motion controllers from Faulhaber, such as the new MC 5004/5005 or the MCLM 300x. The -12 version is also available for sin/cos control. Like the other models in the family, the LM 1483 also combines high dynamics (acceleration up to 220 m/s2) with high precision and repeat accuracy (down to 120 µm or 40 µm). Possible applications include automatic placement machines where highly dynamic positioning is required.
Danfoss
Servo technology in focus
Danfoss Drives took its first step towards servo technology in 2015 with an integrated motion controller for the VLT AutomationDrive frequency inverter. Now the Danes want to significantly strengthen their activities in this area with the new...
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
