Smart gas
Andrea Gillhuber,
Measure CO2 content in welding systems
The sensors in the 'FlowEVO' series from Smartgas measure the CO2 content in MAG welding systems and thus allow conclusions to be drawn about the result of the welding process.
© Smart gas
A gas mixture of carbon dioxide (CO2) and argon is often used for so-called shielding gas welding. Argon as an inert gas is responsible for the stability of the arc. The sensors 'FlowEVOCO2 in Ar 30 Vol.-% l F3-216307-05000' and 'FlowEVOCO2 in Ar 3000 ppm l F3-216305-05000' from Smartgas measure theCO2 content in the welding systems. This allows conclusions to be drawn about the quality of the joining process, for example the penetration behavior and the metallurgy of the workpiece.
Sensor+Test 2022
Finally live again in Nuremberg
Sensor+Test will take place in Nuremberg from May 10 to 12, 2022. At the annual press conference of the AMA Association for Sensors and Measurement, the organizer already gave an overall positive outlook for the trade fair for sensor, measuring and...
Current products
News about sensor technology
What would the smart factory of today and tomorrow be without sensors? Sensors are indispensable as the basis of every industrial production system. Computer&AUTOMATION has summarized current trends from spring 2017 in a picture gallery.
Gas sensors
No chance of leaks
The main area of application for sulphur hexafluoride is the insulation of high-voltage electrical switchgear. As the non-toxic gas is the strongest of all greenhouse gases, its use is subject to the strictest environmental regulations - and special...
