iC-Haus at SPS 2025
System-on-chip for optical absolute encoders
New from IC-Haus is the 'iC-RT2624' system-on-chip (SoC) for optical encoders with contamination-tolerant scanning.
© iC House
The microelectronics integrated in the compact 7 mm × 5 mm optoQFN housing deliver exact measured values even with high mounting tolerances, according to the supplier. The core is the interpolation circuit with filtering, which reliably records the angle of a 26 mm code disk with 26-bit resolution. The digitized angle information is available to the serial interfaces BiSS, SSI or SPI in less than 1 µs. A programmable ABZ generator with 'FlexCount' quadrature resolution adapts to any control system. Thanks to auto-calibration and eccentricity compensation, encoder systems with the iC-RT2624 achieve an angular accuracy of less than 0.01°. On-chip calibration can be carried out via the BiSS and SPI serial interfaces or at the touch of a button. The dimensions of the code disk can be freely adapted from an outer diameter of 20 mm with a FlexCode design. The programmable sin/cos generator can be set with 2n CPR (n = 0..15) independently of the basic resolution of the respective code disk. In parallel, the native sin/cos resolution is available for output and is routed in a separate, safety-ready signal path.
Hall 4A Stand 146
Hengstler
Compact Absolute Encoder
According to the manufacturer, the 'Acuro AM34' absolute encoder from Hengstler is the most compact encoder in its class and even fits into driverless transport vehicles and cobots.
iC House
Magnetic position sensors
The 'iC-TW39' TMR angle sensor for on-axis applications from iC-Haus is suitable for high-resolution incremental and absolute measuring systems and also supports multi-turn applications.
iC House
Changes in the management
iC-Haus appoints Dr. Alexander Flocke as additional Managing Director alongside Dr. Heiner Flocke. Technical Managing Director and co-owner Manfred Herz takes over the 'Pre-development' department.
Sick
Sales growth in a turbulent market environment
Thanks to innovations and a focus on strategic industrial markets, Sick was able to moderately increase its sales in the 2025 financial year. In a turbulent market environment, the company was able to maintain its position and gain market share with...
