Micro-Epsilon
Draw-wire displacement sensors for industrial applications
Draw-wire sensors in the Wiresensor WPS-K100 series from Micro-Epsilon measure paths and distances in industrial environments. Two new models have measuring ranges of 1500 and 2500 mm.
© Micro-Epsilon
The draw-wire sensors of the Wiresensor family from Micro-Epsilon are available in many sizes, designs and versions. Two draw-wire displacement sensors from the Wiresensor WPS-K100 series with measuring ranges of 1500 mm and 2500 mm are being launched for industrial applications. This sensor series is used for precise distance and position measurement, primarily for measuring tasks in mobile machines, mobile cranes and in lifting technology. Their plastic housing is glass fiber reinforced. The drum and spring chamber are housed separately so that the sensors are protected from external influences and can be used both indoors and outdoors. For OEM and series applications, the sensors can be easily adapted to the respective measuring task, including via the measuring range, cable thickness or various signal outputs.
Micro-Epsilon
For long signal paths
The capaNCDT 61x4 capacitive measuring system from Micro-Epsilon is used for industrial measurement of displacement, distance and position. Unlike conventional capacitive sensors, the preamplifier of the active 'capaNCDT' sensors is integrated in...
Turck duotec
The digital nose
Turck duotec is a strategic partner in the deeptech start-up SmartNanotubes Technologies. The two companies are developing and industrializing a digital nose that enables devices and machines to smell.
Pepperl+Fuchs
From the sensor to the cloud
One of the 'magic formulas' in the Industrial Internet is 'continuous information flow'. However, the installed base of production cannot be 'converted' as easily as business software. Instead, the migration must integrate different components.
Megatron
Angle measurement in the smallest space
Thanks to their housing depth of just 6 mm and a housing diameter of 16.4 mm, the hollow-shaft conductive plastic potentiometers in the 'MHP16' series from Megatron are particularly suitable as position indicators in motor valves and actuators.
Micro-Epsilon
Confocal chromatic precision sensor
The confocal chromatic sensor 'IFS2407-1.5' expands Micro-Epsilon's 'confocalDT' sensor portfolio and is used for high-precision displacement and thickness measurement. The sensor has a measuring range of 1.5 mm with a base distance of 17 mm.
