Micro-Epsilon
Laser distance sensors with IO-Link
The optoNCDT ILR2250 laser distance sensors from Micro-Epsilon can also be integrated into automation systems via IO-Link, enabling seamless communication from the sensor-actuator level to the system control.
© Micro-Epsilon
The laser distance sensors measure at distances of up to 150 m in automation and industrial applications. Measurements are possible on metal as well as on plastic, paper or textiles. Integration via IO-Link enables simple integration into all common fieldbus and automation systems and dynamic modification of sensor parameters.
The sensor from Micro-Epsilon is suitable for both indoor and outdoor use. Its robust die-cast aluminum housing was designed for industrial environments. In applications such as in the steel industry and in transport, logistics and conveyor technology, coil diameters and crane positions are detected, fill levels in silos are measured, diameters on seamlessly rolled rings are monitored and drone-based distance measurements are carried out.
Micro-Epsilon
Thermal imaging camera with spotfinder
The thermoImager TIM41 thermal imaging camera from Micro-Epsilon is robust and optimized for industrial applications. According to the manufacturer, it offers a high resolution and a wide temperature range from -20 to +900 °C for monitoring machines...
Micro-Epsilon
For long signal paths
The capaNCDT 61x4 capacitive measuring system from Micro-Epsilon is used for industrial measurement of displacement, distance and position. Unlike conventional capacitive sensors, the preamplifier of the active 'capaNCDT' sensors is integrated in...
Micro-Epsilon
Confocal chromatic precision sensor
The confocal chromatic sensor 'IFS2407-1.5' expands Micro-Epsilon's 'confocalDT' sensor portfolio and is used for high-precision displacement and thickness measurement. The sensor has a measuring range of 1.5 mm with a base distance of 17 mm.
