ASM
Displacement measurement for measuring lengths up to 5750 mm
ASM has a sensor solution for hydraulic cylinders which, according to the supplier, considerably simplifies installation and maintenance: posichron EasyMount is an absolute, non-contact and wear-free displacement measuring system for measuring lengths of up to 5750 mm.
© ASM
The core of the system is a strong, maintenance-free magnet that is mounted inside the cylinder. The sensor itself is mounted on the outside of the hydraulic cylinder, so no deep hole drilling is required for installation. In the event of maintenance or repair, the sensor is easily accessible from the outside. This means that sensors can also be fitted to small piston diameters with limited installation space, where there is no room for internal mounting.
Installation in synchronized cylinders is also possible. Redundant sensor configurations are possible up to four times. Various designs are available (including rod, profile and ultra-flat profile versions), the protection class is up to IP68/IP69. The sensors achieve a linearity of up to 0.02 % of the measuring length.
Baumer
Measured value is available in 15 s
The CombiLyz conductivity sensor from Baumer helps with the phase separation of food, water and cleaning liquids. It measures the electrical conductivity of the passing medium and draws conclusions about the type of medium and its concentration.
Fraunhofer IPA
Calculated leakages
Using calculation to generate compressed air leaks in a system was an unusual requirement for the compressed air and pneumatics specialist Mader, which commissioned Fraunhofer IPA to visualize the effects of compressed air leaks live.
