Baumer
Measured value is available in 15 s
The CombiLyz conductivity sensor from Baumer helps with the phase separation of food, water and cleaning liquids. It measures the electrical conductivity of the passing medium and draws conclusions about the type of medium and its concentration.
© Baumer
Thanks to its short response time for temperature compensation, the exact measured value for conductivity is available in 15 seconds. The reason for the fast temperature compensation of the 'CombiLyz AFI' is a cap made of PEEK plastic in a one-piece hygienic design, which contains the inductive sensor elements for measuring the electrical conductivity and the temperature sensor.
Only sensors with a two-piece cap, where the temperature sensor is located under metal, are faster. A coloured touch display facilitates parameterization, freely definable conductivity ranges can be assigned to any display color, for example blue for water and red for acid. This means you can see from a distance which medium is currently flowing through the pipe. The sensor transmits its measured values via a 4 to 20 mA interface with optional HART protocol.
TZ 1 OSADL
Support with license compliance
The use of open source software in industrial products is indispensable today. However, the use of this software requires suitable processes to be established in the company on how to deal with open source in order to achieve license compliance.
Baumer
Reliably recognize the finest details
Baumer is expanding the 10 GigE cameras in the 'LX' series with four new models. The cameras with Sony Pregius S sensors deliver 50 fps at 24 megapixels; more resolution is available with the 65 megapixel Gpixel models at 18 fps.
